Hd lyd??
5/9/2006 2:07:06 PM #1 av 8
Postet av: Even Sundgot
Hei:
Eg var inne på hifiklubben i ålesund og såg meg om kring og då hørte eg på eit anleg som dei sa att det spelte i hd lyd.. :D
Kva er hd lyd?? :D
5/9/2006 2:24:51 PM #2 av 8
Postet av: nullpeiling
Det er kanskje DVD-AUDIO eller SACD du tenker på
5/10/2006 11:15:54 AM #3 av 8
Postet av: kWern
Tja, du har jo også Dolby Digital TrueHD, som filmer på HD-DVD har.
klipp og lim:
Dolby TrueHD
Dolby® TrueHD is Dolby’s next-generation lossless technology developed for high-definition disc-based media. Dolby TrueHD delivers tantalizing sound that is bit-for-bit identical to the studio master, unlocking the true high-definition entertainment experience on next-generation discs. When coupled with high-definition video, Dolby TrueHD offers an unprecedented home theater experience that lets you enjoy sound as stunning as the high-definition picture.
Features
* 100 percent lossless coding technology.
* Up to 18 Mbps bit rate.
* Supports up to eight full-range channels of 24-bit/96 kHz audio.*
* Supported by High-Definition Media Interface (HDMI™), the new single-cable digital connection for audio and video.
* Supports extensive metadata including dialogue normalization and dynamic range control.
*Dolby TrueHD can support more than eight audio channels. HD DVD and Blu-ray Disc standards currently limit their maximum number of audio channels to eight.
Benefits
* Delivers enthralling studio-master-quality sound that unlocks the true high-definition entertainment experience on next-generation discs.
* Offers more discrete channels than ever before for impeccable surround sound.
* Compatible with the A/V receivers and home-theaters-in-a-box (HTIBs) of today and tomorrow.
* Dialogue normalization maintains the same volume level when you change to other Dolby Digital and Dolby TrueHD programming.
* Dynamic range control (Night mode) enables you to customize audio playback to reduce peak volume levels (no loud surprises) while experiencing all the details in the soundtrack, enabling late-night viewing of high-energy surround sound without disturbing others.
* Selected as the mandatory format for HD DVD and as an optional format for Blu-ray Disc.
Next-Generation High Definition Disc Players are Compatible with Current A/V Receivers
Whether you own an older audio/video (A/V) system equipped with Dolby® Digital, or a newer A/V receiver equipped with an HDMI™ connection or external line-level multichannel inputs, you are assured of a compatible, high-quality playback path.
Hentet fra http://www.dolby.com/consumer/technology/trueHD.html
5/10/2006 12:20:06 PM #4 av 8
Postet av: Tannoy
"kWern" skrev:Tja, du har jo også Dolby Digital TrueHD, som filmer på HD-DVD har.
klipp og lim:
Dolby TrueHD
Features
Benefits
Lite sannsynlig at dette er tilgjengelig for oss på bjerget ennå...
5/10/2006 2:00:22 PM #5 av 8
Ok men kva er så spelsielt med hd lyd forhold tail vaneli er lyden klarere eller? :D
5/10/2006 2:24:01 PM #6 av 8
Postet av: kWern
"Even Sundgot" skrev:Ok men kva er så spelsielt med hd lyd forhold tail vaneli er lyden klarere eller? :D
Ja, det er vel det man ønsker på nye lydformater. Med høyere mendge på datastrømmen, er det rom for flere detaljer og mer dynamikk i lydbildet, og lyden er mindre komprimert, slik at kunstig støy som følge av komprimering reduseres (f.eks. tunnelsuset og ekkoet du får med hardt komprimert MP3-lyd med lav bitrate). Det er også rom for flere kanaler (8 kanaler (7.1) i motsetning til 6 (5.1)).
Men dataene tar da mer plass, og derfor har dette først vært mulig med HD-DVD og BlueRay.
Men om du har ører og elektronikk til å få noe utbytte av dette, er jo en annen sak.
5/13/2006 1:40:23 PM #7 av 8
Postet av: Snickers-is
"HD-lyd" følger av formatet på plata men er i praksis det samme som DVD-Audio.
MVH
Jørn Rune Kviserud
Midgard Audio
Creative HiFi
CNC Xpress
AV expo
5/13/2006 2:58:37 PM #8 av 8
Ok då forstår eg.. :D
takkar :D
